Marsky's avatar
Marsky
Follower
May 03, 2016
GS728TPSB - Change SFP Stacking mode to optical uplink mode
Hello,
I have a Netgear Switch type GS728TPSB and I cannot use the SFP Port 27 and 28 to connect a typical network videoencoder.
Ports 23 - 26 are working with this encoder, but Port 27 and 28 not.
I saw the following information in the datasheet regarding Port 27 and 28:
2 x SFP slots (port 27 and 28) to
support 1 G optical module (uplink)
and 2.5 G stacking (via stacking
cable AGC761)
It seems, that in the default settings this port is in the "Stacking-mode". How is it possible to change this to a normal "optical-mode (Uplink)"?
I opened also the webbrowser of this netgear switch, but I didn't find a way to change this. It was not possible to change it.
Do you have a ideo, how to change it? Where in detail can I find this setting in the webbrowser?
Or is it not possible?
Best Regards,
Marcel
  • I believe the setting is under System > Stacking > Advanced > Stack Port Configuration, and you'll have to check on one of the stacking ports and change its Configured Stack Mode to Ethernet.
    • Danthem's avatar
      Danthem
      NETGEAR Employee Retired
      mgmtmt is correct. Note that you will most likely need to reboot after changing and applying for this take effect (I'm like 99% sure of this, but haven't tested it in quite a while so my info might be a bit outdated :) )
ProSupport for Business
