rajkulkarni
Nov 30, 2017Aspirant
GS748 - Saving and Restoring Switch Settings
I would like to know how to save and restore switch settings on our Netgear Prosafe GS748T. The Model Name is :GS748Tv4H2
TheEther
Nov 30, 2017Guru
Use "Upload" to save and "Download" to restore switch settings. You can find details in the manual:
http://www.downloads.netgear.com/files/GS700TP_UM_08May08_.pdf
rajkulkarni
Dec 01, 2017Aspirant
What is the filetype, "Code"? Also, what is its purpose? (See attachment)
Will saving the configuration in a text file allow me to import it later?
- TheEtherDec 01, 2017Guru"Code" is firmware. You can save a copy of the firmware.
Yes, you can import a text configuration.
