John1414
Jan 22, 2018Aspirant
GS748T v5 vlan
Hi Guys, Trying to configure vlan but not having much luck could someone please assist right now I have one vlan 192.168.1.x but need to add another vlan which would 192.168.30.x how I do go ...
schumaku
Jan 23, 2018Guru - Experienced User
Well, somehting must handle the routing - either a L3 function on a switch, or a router.
- John1414Jan 23, 2018Aspirant
Thanks for respone but is this switch layer 3 ?
- schumakuJan 23, 2018Guru - Experienced User
According to the GS716Tv3/GS724Tv4/GS748Tv5 Datasheet the switch does support these lite L3 features:
L3 SERVICES - IPV4 ROUTING
Static Routing Yes
VLAN Routing Yes
IP Source Guard Yes
Your reading does start in GS716TV3/GS716Tv3/GS724Tv4/GS748Tv5 Software Administration Manual (25 Sept 2013) with Chapter 4, Configuring Routing. There is more than defining the VLAN interfaces for routing, ie. adding Routing Rules for example.
Thanks for that but the doc still not clear do I need to add my default vlan1 under VLAN Routing Configuration and assign IP for it ?
Also is there CLI for these switches I tried ssh and telnet via putty it doesnt work.
