John1414
Jan 22, 2018Aspirant
GS748T v5 vlan
Hi Guys, Trying to configure vlan but not having much luck could someone please assist right now I have one vlan 192.168.1.x but need to add another vlan which would 192.168.30.x how I do go ...
schumaku
Jan 23, 2018Guru - Experienced User
Well, somehting must handle the routing - either a L3 function on a switch, or a router.
John1414
Jan 23, 2018Aspirant
Thanks for respone but is this switch layer 3 ?
- schumakuJan 23, 2018Guru - Experienced User
According to the GS716Tv3/GS724Tv4/GS748Tv5 Datasheet the switch does support these lite L3 features:
L3 SERVICES - IPV4 ROUTING
Static Routing Yes
VLAN Routing Yes
IP Source Guard Yes
Your reading does start in GS716TV3/GS716Tv3/GS724Tv4/GS748Tv5 Software Administration Manual (25 Sept 2013) with Chapter 4, Configuring Routing. There is more than defining the VLAN interfaces for routing, ie. adding Routing Rules for example.
- John1414Jan 23, 2018Aspirant
Thanks for that but the doc still not clear do I need to add my default vlan1 under VLAN Routing Configuration and assign IP for it ?
Also is there CLI for these switches I tried ssh and telnet via putty it doesnt work.
- schumakuJan 24, 2018Guru - Experienced User
Hm, otherwise it's not available for adding static routes, isn't it?
The Netgear Smart Managed Plus and Smart Managed Pro don't have an (accessble) CLI.
