AsapComputers
Dec 14, 2022Follower
GS748Tv5 how to disable telnet access
Can someone here tell me how to disable telnet on GS748Tv5 please. Thanks in advance Ian
Marc_V
Dec 15, 2022NETGEAR Employee Retired
Welcome to the Community!
Telnet should be disabled by default. If remote management is enabled on the switch disabling it will also disable Telnet.
HTH
schumaku
Dec 15, 2022Guru - Experienced User
On the Smart Switches this would be a little bit difficult. The moment the management ip is configured, the remote management is enabled.
This is everything the RTFM says on the subject:
"To enable remote management of the switch through a web browser or SNMP, you must
connect the switch to the network and configure it with network information (an IP address,
subnet mask, and default gateway). The switch has a default IP address of 192.168.0.239
and a default subnet mask of 255.255.255.0. "
This is why users are asking or more controls.
