itc_apollonio
May 10, 2018Follower
GS752TP VLAN routing NO INTERNET
Hi,
I need to create a VLAN routing but following the instructions by manual or forums it doesn't work.
Here the situation:
VLAN default: IP address 10.4.1.0 sub 255.255.255.224 gateway 10.4.1....
Anonymous
May 11, 2018Hi itc_apollonio,
Welcome to the community!
1. As VLAN1 clients can access each other and Internet----so Internet is ok, and VLAN1 config is OK.
2. As VLAN4 client can access each other, but cannot access Internet----so VLAN4 config is OK. Maybe it's route problem. On the switch, you have add a default route, next hop point to the Gateway. So please check on the Gateway, whether there is back route to VLAN4 network(192.168.0.1/24, next hop point to 10.4.1.67) or not? If not, it should be the root cause.
Hope it helps!
EricZ
NETGEAR employee
