trnX
Jul 14, 2022Initiate
GS752TPS, GS752TXS - Need help with SNMP and fans state
Hello,
I have a similar problem as user milp (from this topic: https://community.netgear.com/t5/Plus-and-Smart-Switches-Forum/Reading-GS752TXP-fan-speed-with-SNMP/m-p/1999330)
I need to read fan table (discover fans) and their state via SNMP. I have switch GS752TPS (version 5.3.0.25), where it works with this OIDs:
1.3.6.1.4.1.4526.10.43.1.6.1.1 (boxServicesFansIndex)
1.3.6.1.4.1.4526.10.43.1.6.1.3 (boxServicesFanItemState)
from this MIB: NETGEAR-BOXSERVICES-PRIVATE-MIB
I have second switch GS752TXS (version 6.1.0.27) where this OIDs don´t work (you can see in attachment..)
Both switches has NETGEAR-BOXSERVICES-PRIVATE-MIB in supported mibs list.
Is there any solution to obtain data about fans via SNMP?
Thank you
Welcome to the Community!
Using MIB Browser and I loaded the MIB Version 6.1.0.39 for the GS752TXS.
1.3.6.1.4.1.4526.11.43.1.6.1.1 for boxServicesFansIndex
1.3.6.1.4.1.4526.11.43.1.6.1.3 for boxServicesFanItemState
You GS752TXS is currently in 6.1.0.27 you may have to upgrade to the latest and use the MIB provided here.
HTH or there might be users who can recommend.
- Marc_VNETGEAR Employee Retired
- trnXInitiate
Thank you very much! So fast answer 🙂
Your OIDs works on GS752TXS. And GS748Tv5 works too. Nice!
I downloaded some MIB browser and load MIB and now I see this OIDs too. Thank you!
