pgc
Mar 11, 2017Aspirant
GSM7212P Firmware upgrade
Looks like there might be more than one version of this switch, but not sure how to tell what I have. Serial number is 2TH11952F0033 Current firmware is 9.0.2.18 can I upgrade to 10.0.2.20? W...
- Mar 12, 2017
Check the dual image status under Maintenance and look at "next active".
jak0lantash
Mar 12, 2017Mentor
- pgcMar 12, 2017Aspirant
Thanks for your reply, swapped the acitive next boot round and problem solved
