pgc
Mar 11, 2017Aspirant
GSM7212P Firmware upgrade
Looks like there might be more than one version of this switch, but not sure how to tell what I have. Serial number is 2TH11952F0033 Current firmware is 9.0.2.18 can I upgrade to 10.0.2.20? W...
- Mar 12, 2017
Check the dual image status under Maintenance and look at "next active".
jak0lantash
Mar 12, 2017Mentor
pgc
Mar 12, 2017Aspirant
Thanks for your reply, swapped the acitive next boot round and problem solved
