neidlo's avatar
neidlo
Tutor
Oct 20, 2016
GSM7224v2 loses configuration after power outage
As topic title says - this unit (new to me but secondhand) loses it's configuration after a power cycle.
I don't see any button cell within the unit for volatile memory backup. Surely configuration lives in non-volatile storage?
Am I being dumb and missing something?
  • Hi neidlo
    Welcome to the community!
    Yes configuration lives in non-volatile memory, when it's saved. Until it is saved, it is in RAM only.
    When you configure the switch, it is not saved automatically. Are you using Web Interface (GUI)? A Save button should do it.
    Please let us know if this was the burden or not
  • LaurentMa's avatar
    LaurentMa
    NETGEAR Expert
    Hi neidlo
    • neidlo's avatar
      neidlo
      Tutor
      Thanks for the swift reply. I am using the WEB gui to make basic changes (admin password, unit's IP address) and using the SAVE button on the page.
      So how do I get the unit to reload this after a power outage?
      • neidlo's avatar
        neidlo
        Tutor
        Doh!
        I wasn't actually saving the configuration, only 'Apply' ing it... Now sorted and working :-)
        Thank you for your very valuable time.
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    GFNV,
    You can use the Save Configuration function via the GSM7224v2 web-GUI.  On the web-GUI, click on the Maintenance tab and then click on the Save Config tab at the right section.
    Hope this helps. 🙂
    DaneA
    NETGEAR Community Team
ProSupport for Business
