Dpapacosta
Sep 04, 2016Aspirant
GSM7228PS LAG Issues
Model: GSM7228PS V2 Firmware: 8.0.3.23 OS: Windows Hello all, I had a question about a LAG issue I'm having. I have the GSM7228PS with 2 LAGS set up. 1 is with both SFP+ ports running to ...
- Retired_MemberSep 27, 2016
Hi Dpapacosta,
I find that the LAG Type is different between the GSM7228PS and the GS728T.
In GSM7228PS: the Static Mode is Disabled, which means that the LAG Type is LACP
In GS728T: the LAG Type is Static
So the LAG Type is different, and this different configuration is the reason why the LAG status is down.
So please set the LAG Type to LACP in the GS728T. And I think it will resolve your problem.
Good luck to you!
Best Regards
DaneA
Sep 05, 2016NETGEAR Employee Retired
Hi Dpapacosta,
Welcome to the community! :)
What is the model of the SFP modules you are using?
DaneA
NETGEAR Community Team
- DpapacostaSep 07, 2016Aspirant
The module is an AGM731 on both switchs.
- DaneASep 07, 2016NETGEAR Employee Retired
Hi Dpapacosta,
Let us isolate the problem. Since the LAG connection is working between the GSM7228PS and the XSM7224S, kindly try to set the LAG using other ports (other than ports 21/23 of the GSM7228PS) between the GSM7228PS and GS748T.
You may also try to swap the SFP modules you have used between the GSM7228PS and the XSM7224S with the SFP modules used between the GSM7228PS and GS748T to furhter isolate the problem.
DaneA
Hello,
Thank you the suggestions. I've tried swapping the lag ports on booth switches, and swapping the SFP modules. I've also tried using standard copper connections as well, and the GS748T still won't connect.
