Dpapacosta
Sep 04, 2016Aspirant
GSM7228PS LAG Issues
Model: GSM7228PS V2 Firmware: 8.0.3.23 OS: Windows Hello all, I had a question about a LAG issue I'm having. I have the GSM7228PS with 2 LAGS set up. 1 is with both SFP+ ports running to ...
- Retired_MemberSep 27, 2016
Hi Dpapacosta,
I find that the LAG Type is different between the GSM7228PS and the GS728T.
In GSM7228PS: the Static Mode is Disabled, which means that the LAG Type is LACP
In GS728T: the LAG Type is Static
So the LAG Type is different, and this different configuration is the reason why the LAG status is down.
So please set the LAG Type to LACP in the GS728T. And I think it will resolve your problem.
Good luck to you!
Best Regards
kohdee
Sep 14, 2016Administrator
What's the distance between switch 1 and switch 2 behind the LAG? does the cabling support it?
