Dpapacosta's avatar
Dpapacosta
GSM7228PS LAG Issues
Model: GSM7228PS V2 Firmware: 8.0.3.23 OS: Windows   Hello all,   I had a question about a LAG issue I'm having.  I have the GSM7228PS with 2 LAGS set up.  1 is with both SFP+ ports running to ...
  • Retired_Member's avatar
    Retired_Member
    Sep 27, 2016
    Hi Dpapacosta,
             I find that the LAG Type is different between the GSM7228PS and the GS728T.
             In GSM7228PS: the Static Mode is Disabled, which means that the LAG Type is LACP
             In GS728T: the LAG Type is Static
             So the LAG Type is different, and this different configuration is the reason why the LAG status is down.
             So please set the LAG Type to LACP in the GS728T. And I think it will resolve your problem.
             Good luck to you!
    Best Regards
ProSupport for Business
