Redhatter
May 26, 2018Aspirant
GSM7248: How many LACP groups can be defined?
Hi all,
I'm looking at purchasing a GSM7248 switch (not sure if it'll be "v1" or "v2"; both Umart and Scorptec just say "GSM7248" without saying which one) to replace a Linksys LGS326-AU.
I have ...
- May 29, 2018
Actually… I think I found a better option… the GS748Tv5 states support for 26 LAGs and is half the price.
TheEther
May 26, 2018Guru
Not sure if it's accurate, but the manual says 64 LAGs are supported. manual
Redhatter
(Hmm, brilliant, backspace some trailing whitespace, and this site sends me back to the previous page and loses my reply in the process. Seems composing posts on this site is a bit on the buggy side… but I digress…)
Thanks for the confirmation, looks like this switch is definitely a worthy candidate and I'll probaby re-locate the existing switch elsewhere.
I did try looking, but the data sheet doesn't say and I wasn't sure if I had the right manual or not. Elsewhere I heard rumours of only 8 LAGs being supported on this model, so wanted to try and get a difinitive answer.
- Mar 23, 2019Retired_Member
