bdowden
Dec 08, 2016Follower
gsm7248 v1 Firmware for XMODEM
Hello. I'm brand new to managed switches and I accidentally erased the permanent storage on the switch. After doing research it appears that I need an opr file to restore the firmware through XMO...
Evans-o
Dec 12, 2016NETGEAR Expert
Hello bdowden,
Welcome to NETGEAR community!
Please search and download the frimware version for gsm7248 v1 through the link below:
http://downloadcenter.netgear.com/#searchResults
Unzip it to find the release notes to help you with restoring / upgrading the firmware.
Let us know if this helped.
Thanks
- JohnRoJan 30, 2017NETGEAR Employee Retired
Hi bdowden,
I have sent you a PM for a download link, see if the file will work for recovery.
Thanks,
- JohnRoFeb 02, 2017NETGEAR Employee Retired
Hi bdowden,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
