Bodminman
Oct 06, 2018Aspirant
GSM7248v2 - Netwgear Manager not finding switch and cannot access GUI
Good morning,
I have several of these switched which I have no issues with but one is proving to be a real pain.
Basically, yesterday I needed to confiure Mirroring on one of its ports but wh...
- Oct 09, 2018
Hi there,
I managed to get hold of a serial to usb adapter and and accessed the CLI interface. For some reason the IP had changed from 192.168.0.151 to a 169 address. I ran ezconfig and reconfigured the IP address etc and can now access it.
Many thanks
DaneA
Oct 07, 2018NETGEAR Employee Retired
Hi Bodminman,
Welcome to the community! :)
Kindly try the steps below:
1. Disconnect the GSM7248v2 switch from the existing network.
2. Connect a PC directly to a LAN port to it. Then, assign a static IP address to the PC that is within the IP address range of the GSM7248v2 switch.
3. Check if you can ping the IP Address of the GSM7248v2 switch. If ever you are able to get replies, try to access its web-GUI.
Kindly answer the questions below:
a. What is the behavior of the LED lights of the GSM7248v2 switch?
b. Were you able to get replies and access the web-GUI of the GSM7248v2 switch after doing the steps above?
DaneA
NETGEAR Community Team
Bodminman
Oct 09, 2018Aspirant
Hi there,
Many thanks
