ctav01's avatar
ctav01
GSM7312 - Is there any way to set it to be a Layer 2 switch rather than a Layer 3 switch?
I did a factory reset and it seems to default to a router setup (show run includes "router rip" and "router ospf" lines).  I just want to use it as a simple Layer 2 switch but it looks like there's more involved than just using EZConfig to set passwords and an IP address.  Any suggestions?
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello ctav01,
    Welcome to the community!
    Regarding your question, the GSM7312 is a fully manageable layer 3 switch - it cannot be bypassed (cannot be compare to a layer 2+ switch which can be used as a plug and play switch); However, For it to function like a layer 2 switch, all you need to do is to assign it an IP address with the same subnet as your existing network. You may follow the installation guide  as it mentions on how to assign an IP or how the switch can get its IP from your DHCP server. Once you have assigned an IP to the switch, it should perform like a layer 2 switch for as long as you do not configure any other settings.
    You can also check out our unmanageable series switches if you consider buying one in the near future.
    Hope this helps! I'll look forward to your reply.
    Thanks,
    • ctav01's avatar
      ctav01
      Thanks John.
      I went through EZConfig and set an IP which seemed to work.  I can access it via telnet and the web interface while I'm in the same subnet but I get no response when I try to communicate with it from a different subnet.  I'm guessing there's some routing info that needs to be set on the 7312 but I'm not sure where.  Suggestions?
      • JohnRo's avatar
        JohnRo
        Hi ctav01,
        Now, this is where it gets a little complicated. For you to access the switch with another subnet you will have to create a route from the VLAN accessign it or change the management VLAN. This image below is an example of VLANs being routed using a layer 3 switch:
        If you want to get the details, please click here.
        Hope this information will enlighten you, if you have more questions I suggest posting a diagram.
        Thanks,
ProSupport for Business
