TheGrave's avatar
TheGrave
GSM7312 upgrade
Hi,
I have a GSM7312 running a very old software version - 3.0.3.2. Latest available version is 6.2.0.14. In the release notes there isn't a word about proper upgrade paths. So questions:
1) Is it safe to go from version 3 to version 6?
2) Do I need to do a factory reset or something after the upgrade? I know a lot of devices change config formats and mess up their configs if not resetted.
3) Is there any official support channel for business devices besides this community btw?
Cheers
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    TheGrave,
    Welcome to the community! :)
    Just to verify.  Is your switch model really a GSM7312?  It is because there is no firmware v3.0.3.2 for the GSM7312.  As reference, kindly check the GSM7312 Firmware and Software Downloads page here.
    The firmware v3.0.3.2 is for the GS108Tv1 (v = version).  As reference, kindly check the GS108Tv1 Firmware and Software Downloads page here.
    DaneA
    NETGEAR Community Team
      • DaneA's avatar
        DaneA
        @TheGrave,
        Thanks for the link to the old thread. :)
        The link to the old firmware versions for the GSM7312 were removed. However, I found the link to the GSM7312 firmware v5.1.1.3.  Kindly download it here and upgrade the switch firmware.  Afterwards, do a ladderized upgrade to firmware v6.0.0.15 up to the latest firmware which is v6.2.0.14.
        Note: Please read the instructions and release notes on the zip file.
        DaneA
ProSupport for Business
