ibhockeyplayer
May 30, 2014Aspirant
GSM7324 Upgrade Help
I have a GSM7324 and need to upgrade the firmware form 2.0.1.12 and untimely to 6.3.3.6 if possible. I’m looking for the upgrade path and the software needed. Thanks.
ibhockeyplayer
Hello and thanks for the info, the doc for 5.1.1.3 states that the migration from 3.x or 4.x to 5.1.1.3. I have 2.0.1.12, so how can I get from 2.0.1.12 to 3.x or 4.x from there? If I can where can I find the older software versions so I can do the upgrades incrementally? Thank you for the help.
