ibhockeyplayer
May 30, 2014Aspirant
GSM7324 Upgrade Help
I have a GSM7324 and need to upgrade the firmware form 2.0.1.12 and untimely to 6.3.3.6 if possible. I’m looking for the upgrade path and the software needed. Thanks.
jmizoguchi
May 30, 2014Virtuoso
btw.. GSM7324 is EOL
http://netgear.com/landing/eol.aspx
Probably that is the reason they will not give you any of older files
It has been replaced by GSM7328S-200
