ibhockeyplayer
May 30, 2014Aspirant
GSM7324 Upgrade Help
I have a GSM7324 and need to upgrade the firmware form 2.0.1.12 and untimely to 6.3.3.6 if possible. I’m looking for the upgrade path and the software needed. Thanks.
ibhockeyplayer
Yes i know its EOL but i still should be able to upgrade it. So is this the software i should be using GSM7328S-200 for my GSM7324? Or it that the new version.
