ibhockeyplayer
May 30, 2014Aspirant
GSM7324 Upgrade Help
I have a GSM7324 and need to upgrade the firmware form 2.0.1.12 and untimely to 6.3.3.6 if possible. I’m looking for the upgrade path and the software needed. Thanks.
jmizoguchi
May 31, 2014Virtuoso
Good luck. Your luck wold be someone sees that has those files if Netgear no longer asset with it.. :)
