fabiogc
Aug 03, 2017Aspirant
GSM7328FS switch - Configuration via the Boot Menu?
I have a GSM7328FS switch and when updating the image an error occurred in which it corrupted the code crc, operating system and backup image. Currently it only accesses via serial cable and already...
fabiogc
Aug 11, 2017Aspirant
Hi,
Yes, I can access the boot menu through the console, in fact it is currently the only access. But I can not transfer any files to the device or at least valid.
If you have a procedure or something, I thank you.
Grateful.
JohnC_V
Aug 12, 2017NETGEAR Employee Retired
That is also the only way that we can recover or upload the firmware. May you be able to take a screenshot of the initialization of the switch?
- fabiogcAug 14, 2017Aspirant
Hello John,
Here is the only valid switch configuration image.
I'm waiting and grateful for the help.
Fabio- JohnC_VAug 15, 2017NETGEAR Employee Retired
As you can see on the menu. Please choose "14 Upload a file through XMODEM" using the firmware that you want to upload on the switch. Please make sure that the firmware is now .stk format.
- fabiogcAug 17, 2017Aspirant
Hi Jonh, Follows image of error after process of item 14 of boot menu. GratefulErro após processo
