pgtds
Jan 09, 2013Aspirant
GSM7328S - enable password
Hi there, I have a GSM7328S which has been running stock since purchase, I'm trying to set it up and I've been configuring other models without any major issues. This one does not appear to wa...
pgtds
Jan 10, 2013Aspirant
jmizoguchi wrote: may suggest to do from other method like GU instead. Not that CLI shouldn't work .. :)
I've had a look at the manual you have linked and I cannot find any reference to the enable password, are you able to point me in the right direction?
