bemke
Dec 05, 2012Aspirant
GSM7328Sv2 firmware updating failed
I have a problem updating the firmware on a GSM7328Sv2 switch from 8.0.3.11 to 10.0.0.19. When I attempt the update using the http method I get a message saying the file transfer process failed. D...
jmizoguchi
Dec 05, 2012Virtuoso
10.0.0.19
download and look at NOTES attached in the ZIP file. Above statement was in the ZIP file >html notes.
Looks like you should able to but you may need to use 8.0.3.34 before you can go 10.
Warning! This firmware image is not compatible with the follow products:
GSM7328Sv1 (serial number starts with 18K, 1J8)
GSM7352Sv1 (serial number starts with 18J, 1J9)
GSM7328FSv1 (serial number starts with 1
