bemke
Dec 05, 2012Aspirant
GSM7328Sv2 firmware updating failed
I have a problem updating the firmware on a GSM7328Sv2 switch from 8.0.3.11 to 10.0.0.19. When I attempt the update using the http method I get a message saying the file transfer process failed. D...
bemke
Dec 06, 2012Aspirant
Thank you for your responses!
The switch is version 2 (confirmed by comparing the starting characters of the serial number).
I will try installing version 8.0.3.34 and see what happens. If successful then I can try installing version 10.0.0.9 again.
