prodigerati's avatar
prodigerati
GSM7352S Cannot create LAG? License is missing?
After updating firmware I cannot create new LAG using the web interface. I get a javascript error that says "Error! cannot create LAG_10..."
I noticed the license is also blank and doesn't have LAG listed as a service:
License Key
License DateNA
License Copy0
License StatusInactive
DescriptionLicense key is not present.
License Features
IGMP
MCAST
PIMDM
DVMRP
PIMSM
OSPFV3
IPV6
How do I fix this issue?
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi prodigerati,
    Have you tried using other browsers like Firefox or Safari to access the web-GUI then configure LAG on the GSM7352S?
    Have you tried using other PCs as well?
    DaneA
    NETGEAR Community Team
    • prodigerati's avatar
      prodigerati
      Safari, Chrome, IE, Firefox all give me the same error:
      Error! Failed to Set 'Admin Mode' with 'Enable'
      Error! Failed to Set 'Hash Mode' with 'Src IP and Src TCP/UDP Port fields'
      Error! Failed to Set 'STP Mode' with 'Enable'
      Firmware 8.0.3.49
      • DaneA's avatar
        DaneA
        Hi prodigerati,
        I believe this is the same GSM7352S switch from your other recent posts.  Since you were able to access the GSM7352S web-GUI, have you tried to perform a factory reset?  On the web-GUI, kindly go to Maintenance > Reset > Factory Default.
        If you are unable to perform factory reset via the web-GUI, kindly have a console access on the GSM7352S and issue the CLI command: clear config to factory reset the GSM7352S then reconfigure it from scratch.
        DaneA
ProSupport for Business
