prodigerati
Oct 13, 2015Aspirant
GSM7352S Cannot create LAG? License is missing?
After updating firmware I cannot create new LAG using the web interface. I get a javascript error that says "Error! cannot create LAG_10..." I noticed the license is also blank and doesn't have L...
DaneA
Oct 14, 2015NETGEAR Employee Retired
Hi prodigerati,
I believe this is the same GSM7352S switch from your other recent posts. Since you were able to access the GSM7352S web-GUI, have you tried to perform a factory reset? On the web-GUI, kindly go to Maintenance > Reset > Factory Default.
If you are unable to perform factory reset via the web-GUI, kindly have a console access on the GSM7352S and issue the CLI command: clear config to factory reset the GSM7352S then reconfigure it from scratch.
DaneA
NETGEAR Community Team
prodigerati
Oct 14, 2015Aspirant
Yes this is the same unit. Once I logged into the Web-GUI I did a factory reset. Should I try another factory reset or do a reset via console?
Thanks,
