user42271653
Nov 23, 2022Follower
GSM7352Sv2 10.0.0.44 firmware
I'm trying to find the SNMP MIB files forGSM7352Sv2 with 10.0.0.44 firmware. However, for the GSM7352Sv2 page on http://www.netgear.com/support/product/GSM7352Sv2.aspx#download the only thing present...
DaneA
Dec 26, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
I inquired your concern to the higher tier of NETGEAR Support and got a feedback that the switch likely uses standardized MIBs.
For further assistance, I suggest you to open a support ticket with the NETGEAR Support Team here at anytime.
DaneA
NETGEAR Community Team
schumaku
Dec 26, 2022Guru - Experienced User
And the proprietary switch MIB have sent to the moon unreplaced? Netgear has become extremely unreliable in providing what your customers expect. Time to investigate what Cisco SMB or FS can do better... Does the switch product management follow the absurd way of ReadyNAS? Then good night Netgear!!! Yes, I'm aware LaurentMa isn't in charge here. But you might be able to talk to the right stakeholders svp. The sad story seems to repeat and there are no more tech PM - just marketing ****.
