ZNikke
Jan 12, 2018Aspirant
SNMP MIBs for GSM7352Sv2 10.0.0.53 firmware
Hi!
I'm trying to find the SNMP MIB files for GSM7352Sv2 with the current 10.0.0.53 firmware.
For other models, the MIBs are on the download page next to the firmware download package.
However, for the GSM7352Sv2 page on http://www.netgear.com/support/product/GSM7352Sv2.aspx#download the only thing present are the MIBs for the older 8.0.3.28 firmware, and those don't work correctly when checking fan status etc.
Please advise.
Here is the latest MIB file v10.0.0.56. No password needed. Link will expire after 48hr period.
- JohnC_VNETGEAR Employee Retired
Hi ZNikke,
Welcome to our community!
Let me try if I can get other MIBs for GSM7352Sv2 with current 10.0.0.53 fw. I'll keep you posted.
- ZNikkeAspirant
Thanks, they seem to work OK despite the version mismatch (latest downloadable firmware version is 10.0.53 which is older than the 10.0.0.56
which seems to be the version these MIBs were built for).
You're very much welcome. I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
