ZNikke
Jan 12, 2018Aspirant
SNMP MIBs for GSM7352Sv2 10.0.0.53 firmware
Hi! I'm trying to find the SNMP MIB files for GSM7352Sv2 with the current 10.0.0.53 firmware. For other models, the MIBs are on the download page next to the firmware download package. Ho...
- Feb 12, 2018
Here is the latest MIB file v10.0.0.56. No password needed. Link will expire after 48hr period.
JohnC_V
Feb 12, 2018NETGEAR Employee Retired
ZNikke
Feb 13, 2018Aspirant
Thanks, they seem to work OK despite the version mismatch (latest downloadable firmware version is 10.0.53 which is older than the 10.0.0.56
which seems to be the version these MIBs were built for).
- JohnC_VFeb 13, 2018NETGEAR Employee Retired
You're very much welcome. I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
