maarty
Nov 14, 2018Follower
SNMP MIBs for GSM7352Sv2 10.0.0.53 firmware
I'm trying to find the SNMP MIB files for GSM7352Sv2 with the current 10.0.0.53 firmware.
For other models, the MIBs are on the download page next to the firmware download package.
However, for the GSM7352Sv2 page on http://www.netgear.com/support/product/GSM7352Sv2.aspx#download the only thing present are the MIBs for the older 8.0.3.28 firmware, and those don't work correctly when checking fan status etc.
There is a existing solution signed as accepted but the link to the dowmload inside wa opened only for 48 hours so it is not a solution for other people.
Thanks
Martin
1 Reply
- JohnC_VNETGEAR Employee Retired
Hi maarty,
Welcome to our community! :)
Here is the latest MIB for GSM7352Sv2. No password needed and the link will expire after 48 hour period. Just let me know if this would suffice.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
