ksmizzle
Nov 29, 2016Aspirant
GSM7352Sv2 No Operational Code
Received this switch second hand, appears to be EOL. Switch did not come with operational code, images, or backup images and boots straight to Boot Menu.
NetGear Boot code...... Version 01.00.33 02-03-2011 CPU Card ID: 0x508541 ActiveImage could not be found Unable to open image1 active image failed crc check. activating backup image No Backup Image available. Failed to activate Backup Image. Operational code CRC is invalid. [Boot Menu] 5
Please enter file name on USB Flash drive '/bd0/file name'): gsm73xxSv2-8.0.3.34.stk
Unable to read file "gsm73xxSv2-8.0.3.34.stk".
Error loading code...
From my understanding it appears I may need to use a .opr file, but I cannot find where those are hosted.
What sort of formatting does the USB flash drive need in order to be read? NTFS? FAT32?
Can this work, or do I need the mythical .opr file?
Hi ksmizzle,
Welcome to the community! :)
About the .opr file you needed, kindly click on this link to download it. Hope it helps.
Let us know the results.
Regards,DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
I just want to follow-up on this. Were you able to download and try the .opr file you needed? If yes, what are the results?
Regards,DaneA
- ksmizzleAspirant
DaneA ,
Sorry for the delay on my response, but I found out this morning the switch was taken off my hands and is being returned.
Thank you very much for your assistance, but I was not able to test that .opr file. I would like to believe it would have worked, but I did note the version on it was a bit lower than what was labeled on the device.
V/r,
ksmizzle
