ksmizzle
Nov 29, 2016Aspirant
GSM7352Sv2 No Operational Code
Received this switch second hand, appears to be EOL. Switch did not come with operational code, images, or backup images and boots straight to Boot Menu. NetGear Boot code......
Version 01.00.33 02-...
DaneA
Dec 04, 2016NETGEAR Employee Retired
I just want to follow-up on this. Were you able to download and try the .opr file you needed? If yes, what are the results?
DaneA
NETGEAR Community Team
- ksmizzleDec 05, 2016Aspirant
DaneA ,
Sorry for the delay on my response, but I found out this morning the switch was taken off my hands and is being returned.
Thank you very much for your assistance, but I was not able to test that .opr file. I would like to believe it would have worked, but I did note the version on it was a bit lower than what was labeled on the device.
V/r,
ksmizzle
