LaurentF
Jun 22, 2016Aspirant
GSM7352Sv2 ssh connection stuck after saving changes
I don't know firmware and OS sorry When I wanted to quit from ssh connection, I replied "yes" to save changes. I had the successfull message for saving configuation but never get back the prompt...
DaneA
Jun 26, 2016NETGEAR Employee Retired
Hi LaurentF,
Welcome to the community! :)
Kindly answer the questions below:
a. Have you tried to reboot the GSM7352Sv2 switch then tried to connect via ssh connection?
b. Have you tried using other PC/laptop to isolate the problem?
I look forward to your response.
DaneA
NETGEAR Community Team
LaurentF
Jun 26, 2016Aspirant
Hi DaneA,
Thanks for reply and welcoming !:smileyhappy:
a. I should be able to reboot swtich next week when I'm next to it. (I was only able to access remotly)
b. I have not tried with another PC but with same PC I can ssh connect to many other server.
BTW I will be able to try a console connection via serial cable when I'm next to the switch.
Then I hope I could complete "admin" connection and check setting before I reboot.
Usually, I never saved config settings when I exit because I never made modification. This time I did because I knew that I had to shutdown all the device in the rack where is located switch and I wanted to be sure saved setting wre the same as current active settings !!!
Now I have done some experimenation on similar Netger switch and I understood that even when no modification was made, the switch tell you that you have unsaved settings !!! It is not very convenient because you don't really know if you have unsaved changes or not !
Thanks again and I will post more information when I have netx week....
Rgds
LaurentF
- DaneAJul 04, 2016NETGEAR Employee Retired
Hi LaurenceC,
Just want to follow-up on this. Do you have any updates?
DaneANETGEAR Community Team
- LaurentFJul 19, 2016Aspirant
Hi DaneA,
Sorry for late reply but I was busy until last week and now I'm on vacation !
When I was close to the Netgear switch, I've tried to connect to console port but it was impossible too!
So I decided to reboot it and then I could connect on both console and ssh.
So we can consider that issue is fixed even if one of my colleague told me that the same issue occured when he tried to save some modofocations he did on the setting.
Rgds
LaurentF
