bremke's avatar
bremke
Having trouble changing network management IP and subnet mask on GSM7224v2 switch
I am having trouble changing the network management IP and subnet mask on a Netgear GSM7224v2 switch.
When I use the network parms command the error I get says, "IP Address/Netmask entered conflicts with the configured IP Address/Netmask of a router interface."
A similar error happens in the GUI.
How can I change the the management IP and netmask?
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi bremke,
    Welcome to the community! :)
    In privileged EXEC mode, I suggest you to execute the command "network protocol none" then proceed with the network parms command.
    DaneA
    NETGEAR Community Team
      • bremke's avatar
        bremke
        In privileged EXEC mode the command "network protocol none" results in the IP address, subnet mask, default gateway, and Configured IPv4 protocol being reset as expected.
        (GSM7224V2) #show network
        Interface Status............................... Always Up
        IP Address..................................... 0.0.0.0
        Subnet Mask.................................... 0.0.0.0
        Default Gateway................................ 0.0.0.0
        IPv6 Administrative Mode....................... Enabled
        IPv6 Prefix is ................................ FE80::E291:F5FF:FEA8:B370/64
        Burned In MAC Address.......................... E0:91:F5:A8:B3:70
        Locally Administered MAC address............... 00:00:00:00:00:00
        MAC Address Type............................... Burned In
        Configured IPv4 Protocol....................... None
        Configured IPv6 Protocol....................... None
        IPv6 AutoConfig Mode........................... Disabled
        Management VLAN ID............................. 2
        But the "network parms" command doesn't work. I get a message back saying "IP Address/Netmask entered conflicts with the configured IP Address/Netmask of a router interface.
ProSupport for Business
