Agsy
May 16, 2018Aspirant
Help with L3 DHCP Routing on M4300 series
Hey guys,
I am currently trying to set up L3 DHCP routing on our Netgear M4300-series switches and I am struggeling a bit. Main problem: our core switches M4300-12x12f (as can bee seen on my attach...
- May 17, 2018
Hi Agsy,
Welcome to NETGEAR community!M4300 support the function "UDP Relay" could resolve your concern that relay DHCP service cross different VLAN.
Please check following screenshot and user manual to deploy it.May the solution help you:smileyhappy:
Thanks,
Daniel.
DanielZhang
May 27, 2018NETGEAR Expert
Hi Agsy,
Could you please check the Server IP is available(pingable) on network?
M4300 will try to get ARP(IP/MAC) for server IP before relay packets.(Usually use a ping for it)
Because M4300 need to know the actual IP address and MAC address of server
So if your server IP is behind firewall or not pingable.
We need to add static ARP for it that M4300 will forward correctly with DHCP L3 relay.
Let me know if you have further concern.:smileyhappy:
Thanks,
Daniel.
Agsy
Jun 07, 2018Aspirant
Hi Daniel,
sorry for my late response to your last suggestion. We finally got everything up and running, thanks to your valuable input.
In the end it was just a missing modification to the Windows routing table on our Windows-DHCP server. UDP relaying was working all the time, but the return packets were just mis-routed ;)
I marked your first reply as a solution for my problem.
Cheers
Sascha
