nag4591
Nov 07, 2024Aspirant
How do I use the web interface to backup/restore a configuration on the GS724Tv6?
Hi all, Before suggesting that I go to Maintenance/Upload, I must point out that my Maintenance tab only has the following sub-menus: Reset, Export, Update, File Management and Troubleshooting. ...
nag4591
Hi,
Thanks for your reply. The software I was referring to was the Window-only "Smart Control Center" https://www.downloads.netgear.com/files/SmartControlCenter_03Nov10.pdf
I run Linux. Not Windows. So, I want to backup and restore my config through the device web gui.
Sorry about posting in the wrong place. Tell me what to do about it, and I will do it.
Thank you.
schumaku
Nov 08, 2024Guru - Experienced User
SCC is a relict of the past, some 20 or more 25 years old, combining magiclly some legacy L2 protcols triggering eg. TFTP at some point - features which are disbled by default since several years on all Netger switches. Obsolete digging for a dead horse.
As I said before, I have no access to any GS724T, including the current GS724Tv6. I'm neither Netgear here, but operating bigger nuber of NTGR Smart Managed switches, like GSnnnT and XSnnnT models, and -all- have HTTP and TFTP based up- and download options as described in the GS716Tv3, GS724v4, and GS748Tv5 Software Administration Manual, Chapter 8, Maintenance. I have no reason to believe these controls and functions should no longer be available, neither on the effective devce, nor on the online help - but as said before in a different thread, I can't find the current GS724Tv6 Software Administration Manual, neither.
