nag4591
Nov 07, 2024Aspirant
How do I use the web interface to backup/restore a configuration on the GS724Tv6?
Hi all, Before suggesting that I go to Maintenance/Upload, I must point out that my Maintenance tab only has the following sub-menus: Reset, Export, Update, File Management and Troubleshooting. ...
nag4591
Hi,
Thanks for your reply. The software I was referring to was the Window-only "Smart Control Center" https://www.downloads.netgear.com/files/SmartControlCenter_03Nov10.pdf
I run Linux. Not Windows. So, I want to backup and restore my config through the device web gui.
Sorry about posting in the wrong place. Tell me what to do about it, and I will do it.
Thank you.
ReneD
Nov 18, 2024NETGEAR Moderator
Hello nag4591,
This is a newer version of Netgear Smart switch and as Kur said from the previous replies the Smart control center may not be compatible with the GS724Tv6. There are 2 ways of updating its software either from Insight or doing it on standalone mode. I cannot see its user manual as well but judging from this new switch, it may have the same interface as with the GS110TPv3 and other new switch in the market. Using its user manual below, you may check page 450 of the link to update the software of the switch on standalone.
https://www.downloads.netgear.com/files/GDC/GS108Tv3/GS108Tv3_GS110TPv3_GS110TPP_UM_EN.pdf
Thanks in advance! 🙂
Have a lovely day,
Rene D
Netgear Team
