min-seok
May 24, 2017Aspirant
How many DHCP Pool Configuration can I create?
I get an error after 16th. Can not you create it anymore?
- Jun 04, 2017
Hi mim-Seok and DaneA.
Correct our M4100 are limited to 16 pools , you can check it in our datasheet:
http://www.downloads.netgear.com/files/GDC/datasheet/en/M4100.pdf
If you need more than 16 pools I would recommend our M4300 where the actual limit is 256.
http://www.downloads.netgear.com/files/GDC/datasheet/en/M4300.pdf
Hope it Helps
Xavier Lleixa
NETGEAR CBU PLM
DaneA
May 25, 2017NETGEAR Employee Retired
Hi min-seok,
Welcome to the community! :)
Kindly answer the questions below:
a. What does the exact error message say? It would be best that you post a screenshot of the error message.
b. Have you tried to reboot the M4100-26G switch then try again to create the 16th DHCP pool?
c. What is the current firmware version of the M4100-26G switch?
DaneA
NETGEAR Community Team
min-seok
May 25, 2017Aspirant
Hi DaneA,
Thank you for your response.
After the 16th, that is, the 17th error occurs.
answer a.
(M4100-26G) (Config)#show ip dhcp pool configuration all
Pool: slot01
Pool Type...................................... Dynamic
Network........................................ 192.168.101.0 255.255.255.0
Pool Size...................................... 253
Lease Time..................................... infinite
Default Routers................................ 192.168.101.1
Pool: slot02
Network........................................ 192.168.102.0 255.255.255.0
Default Routers................................ 192.168.102.1
Pool: slot03
Network........................................ 192.168.103.0 255.255.255.0
Default Routers................................ 192.168.103.1
Pool: slot04
--More-- or (q)uit
Network........................................ 192.168.104.0 255.255.255.0
Default Routers................................ 192.168.104.1
Pool: slot05
Network........................................ 192.168.105.0 255.255.255.0
Default Routers................................ 192.168.105.1
Pool: slot06
Network........................................ 192.168.106.0 255.255.255.0
Default Routers................................ 192.168.106.1
Pool: slot07
Network........................................ 192.168.107.0 255.255.255.0
--More-- or (q)uit
Default Routers................................ 192.168.107.1
Pool: slot08
Network........................................ 192.168.108.0 255.255.255.0
Default Routers................................ 192.168.108.1
Pool: slot09
Network........................................ 192.168.109.0 255.255.255.0
Default Routers................................ 192.168.109.1
Pool: slot10
Network........................................ 192.168.110.0 255.255.255.0
--More-- or (q)uit
Default Routers................................ 192.168.110.1
Pool: slot11
Network........................................ 192.168.111.0 255.255.255.0
Default Routers................................ 192.168.111.1
Pool: slot12
Network........................................ 192.168.112.0 255.255.255.0
Default Routers................................ 192.168.112.1
Pool: slot13
Network........................................ 192.168.113.0 255.255.255.0
Default Routers................................ 192.168.113.1
--More-- or (q)uit
Pool: slot14
Network........................................ 192.168.114.0 255.255.255.0
Default Routers................................ 192.168.114.1
Pool: slot15
Network........................................ 192.168.115.0 255.255.255.0
Default Routers................................ 192.168.115.1
Pool: slot16
Network........................................ 192.168.116.0 255.255.255.0
Default Routers................................ 192.168.116.1
(M4100-26G) (Config)#ip dhcp pool slot17
Couldn't create DHCP pool.
answer b.
I tried it, but I get the same error.
answer c.
(M4100-26G) #show version
Switch: 1
System Description............................. M4100-26G ProSafe 24-port Gigabit L2+ Intelligent Edge Managed Switch, 10.0.2.20, B1.0.1.1
Machine Model.................................. M4100-26G
Serial Number.................................. XXXXXXXXXXXXX
Burned In MAC Address.......................... XX:XX:XX:XX:XX:XX
Software Version............................... 10.0.2.20
Bootcode Version............................... B1.0.1.1
Supported Java Plugin Version.................. 1.6
Current Time................................... Jan 1 00:00:43 1970 (UTC+0:00)
Current SNTP Sync Status....................... Other
Thanks!
