min-seok
May 24, 2017Aspirant
How many DHCP Pool Configuration can I create?
I get an error after 16th. Can not you create it anymore?
- Jun 04, 2017
Hi mim-Seok and DaneA.
Correct our M4100 are limited to 16 pools , you can check it in our datasheet:
http://www.downloads.netgear.com/files/GDC/datasheet/en/M4100.pdf
If you need more than 16 pools I would recommend our M4300 where the actual limit is 256.
http://www.downloads.netgear.com/files/GDC/datasheet/en/M4300.pdf
Hope it Helps
Xavier Lleixa
NETGEAR CBU PLM
DaneA
May 25, 2017NETGEAR Employee Retired
Hi min-seok,
Welcome to the community! :)
Kindly answer the questions below:
a. What does the exact error message say? It would be best that you post a screenshot of the error message.
b. Have you tried to reboot the M4100-26G switch then try again to create the 16th DHCP pool?
c. What is the current firmware version of the M4100-26G switch?
DaneA
NETGEAR Community Team
DaneA
Jun 04, 2017NETGEAR Employee Retired
Thanks for the response. Let me inquire your concern if this is a limitation or not on the M4100-26G switch and I'll get back to you one I got a feedback.
DaneA
- XavierLLJun 04, 2017NETGEAR Employee Retired
Hope it Helps
Xavier Lleixa
NETGEAR CBU PLM
- min-seokJun 05, 2017Aspirant
Hi Xavier Lleixa,
Thank you very much for your infomation.
min-seok
