min-seok
May 24, 2017Aspirant
How many DHCP Pool Configuration can I create?
I get an error after 16th. Can not you create it anymore?
- Jun 04, 2017
Hi mim-Seok and DaneA.
Correct our M4100 are limited to 16 pools , you can check it in our datasheet:
http://www.downloads.netgear.com/files/GDC/datasheet/en/M4100.pdf
If you need more than 16 pools I would recommend our M4300 where the actual limit is 256.
http://www.downloads.netgear.com/files/GDC/datasheet/en/M4300.pdf
Hope it Helps
Xavier Lleixa
NETGEAR CBU PLM
DaneA
Jun 04, 2017NETGEAR Employee Retired
Thanks for the response. Let me inquire your concern if this is a limitation or not on the M4100-26G switch and I'll get back to you one I got a feedback.
DaneA
NETGEAR Community Team
XavierLL
Hope it Helps
Xavier Lleixa
NETGEAR CBU PLM
- min-seokJun 05, 2017Aspirant
Hi Xavier Lleixa,
Thank you very much for your infomation.
min-seok
