ttanemori
Dec 16, 2014Aspirant
How to enable Gigabit Optic Ports on M4100-12GF
I am new to optic fibers. We have a feed by fiber cables, and connected it to M4100-12GF. However, it showed no light. Isn't it auto detected? Do I need to enable or configure the ports for optic ...
cshorthill
Feb 24, 2015Novice
Did you have any luck with this ? I am having a similar issue in the logs it says "<14> Jan 1 00:09:58 169.254.100.100-1 DRIVER[47061132]: hpcsfp.c(1161) 148 %% Invalid Transceiver present in the 0/11 (slot/port)"
the transceiver is a AFM735 compatible one that should work according to the vendor.
