ctc_blair
May 11, 2018Follower
How to enable the disabled POE
Hi,
We currently disabled a POE port by mistake. What should we do to enable it back?
DaneA
May 16, 2018NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate your feedback.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
