PrasunMaiti
Aug 05, 2019Aspirant
How to login to XS724EM - 24-Port 10-Gigabit/Multi-Gigabit Ethernet Smart through http/https query
We want to use this switch. So, for automation, it needs to configure the port(basically port negotiation). Could you please tell me how we can provide the http query for - Login/Logut port ne...
schumaku
Aug 05, 2019Guru - Experienced User
Are you aware that Ethernet link speed negotiation is mandatory for 1G and faster ports like 10G? The 10G switch ports don't support 10Mb/s, only 100Mb/s (and up) that's the only link rate that can be configured. Anything above is the default Auto as required by IEEE (and the default for all ports) - so why bother? Not clear what exactly you intend to achieve. Some business security policies might require unused ports disabled (another setting on the port aside of 100M and Auto) - no other (documented) way than using the Web UI.
Either way, there is no public API, neither for Web nor NSDP (as used by the ProSafe Plus Configuration Utility).
PrasunMaiti
Aug 06, 2019Aspirant
Thanks for your information, Basically, I want the Web API documentation.
- schumakuAug 06, 2019Guru - Experienced UserThe APIs are not open - you might have to reverse engineer things.
