IbrahimKhalil
Mar 30, 2024Aspirant
How to map or configure SAS ports with DAC cables in Netgear M4350 switch
We have 2 Netgear M4350 switches and connected with DAC cables (SAS ports / SFP+ DAC) to all devices like server and storage. How can we map the ports and configure the Netgear M4350 switches? ...
schumaku
Mar 30, 2024Guru - Experienced User
What exactly you like to connect or probably interconnect here? Even if the DAC are making use of the same multilane connectors (SFF-8088), this doesn't make an SAS 6Gb adapter an 10Gb Ethernet. Or what are we missing here on your plan?
- IbrahimKhalilMar 31, 2024Aspirant
Actually, we have Netgear M4350 switch. Server and storage are connected to Netgear switch over 10G SFP+ DAC cables.
In server and storage side its showing SAS ports and also in Netgear switch side its showing DAC / ports status is up.
My question is how may we configure the netgear switch to communicating between server and storage. Because its showing DAC in switch side.- schumakuMar 31, 2024Guru - Experienced User
What exactly does this unknown (SAS) storage serving? Either it's SAS (pure block storage) or it's NAS so serving over a network connection (SMB, NFS, iSCSI). DAC can be used for SAN (SAS) or for NAS (Ethernet). To my knowledge, the Netgear switches are pure networking switches, not SAN switches.
- IbrahimKhalilMar 31, 2024AspirantIts actually Block storage not NAS, That is HPE MSA 1040
