erasto
Sep 30, 2023Aspirant
I can not be able to create DHCP on M4300-52G switch.
Can not be able to create DHCP pool on the switch. After saving, switch freeze, and can not allow me to anything, until reboot and login again.
erasto wrote:
Can not be able to create DHCP pool on the switch. After saving, switch freeze, and can not allow me to anything, until reboot and login again.Duplicated here:
I can not be able to create and configure DHCP ser... - NETGEAR Communities
michaelkenward wrote:
Duplicated here:
M4300 does definitively indicate a Managed Switch, these posts are in the appropriate community section already.
erasto wrote:
Can not be able to create DHCP pool on the switch. After saving, switch freeze, and can not allow me to anything, until reboot and login again.Considering the many features (Web UIs, CLI, ...), options, and variables, and in absence of a crystal ball, some more insight what was configured, ... would be more than great. Screenshots could help to clarify, also indicate the firmware version in use.
FMI: M4300 Intelligent Edge Series Fully Managed Stackable Switches, M4300 Series Switches, M4300-96X Modular Switch, User Manual, Software Version or Release 12.0.15 p.97 ff. Configure DHCP Server Settings
- erastoAspirantHello Team,
On this switch (M4300-52G), switch freeze, and I can not do anything there after click apply, on DHCP configurations. I need to create DHCP pools for different VLAN's, from this switch. I upgraded to the last firmware, but still the same problem.- michaelkenwardGuru - Experienced User
erasto wrote:
On this switch (M4300-52G), switch freeze, and I can not do anything there after click apply, on DHCP configurations.While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:Discuss Ethernet Switches Plus and Pro Managed
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
