robfantini
Jul 30, 2017Aspirant
igmp querier address
we run two linux clusters. they use different vlans. they are attached to the stack using LAGS . Now we need to set up IGMP querier and IGMP snooping . Per this document https://kb.netgear...
- Aug 05, 2017
Hi,
These querier addresses can be anything you want really. It is not any actual ip address. What is it then? It is used as part of an election process. There can only be one querier active in a network. If multiple queriers are configured then an election process will begin. Who will be elected the active querier? The switch that has the lowest ip address value configured, in the querier ip field.
So, it is not a good idea to set the querier ip to the same as the switch. It should instead be setup up as an election model. What I would do, is set querier address 1.1.1.1 on the switch I want to be igmp querier primarily. The others I would set 2.2.2.2, 3.3.3.3, etc. As a hierarchical system: if the current querier goes down then the switch with the next lowest querier ip value would take over as querier.
This is important because you probably want your core/distribution switch to be the main querier.
Cheers
robfantini
This is what I've doen so far:
(GSM7352Sv2) >enable (GSM7352Sv2) #configure (GSM7352Sv2) (Config)#set igmp querier (GSM7352Sv2) (Config)#set igmp querier address 10.10.10.1 (GSM7352Sv2) (Config)#exit (GSM7352Sv2) #vlan database (GSM7352Sv2) (Vlan)#set igmp 10 (GSM7352Sv2) (Vlan)#set igmp querier 10 (GSM7352Sv2) (Vlan)#set igmp 15 (GSM7352Sv2) (Vlan)#set igmp querier 15 (GSM7352Sv2) (Vlan)#exit (GSM7352Sv2) #show igmpsnooping querier vlan 10 VLAN 10 : IGMP Snooping querier status ---------------------------------------------- IGMP Snooping Querier VLAN Mode................ Enable Querier Election Participate Mode.............. Disable Querier VLAN Address........................... 0.0.0.0 Operational State.............................. Disabled Operational version............................ 2
Admin Mode..................................... Disable
Multicast Control Frame Count.................. 0
IGMP header validation......................... Enabled
Interfaces Enabled for IGMP Snooping........... None
VLANs enabled for IGMP snooping................ 10
15
- robfantiniJul 30, 2017Aspirant
enabled admin mode:
(GSM7352Sv2) #configure (GSM7352Sv2) (Config)#set igmp (GSM7352Sv2) (Config)#exit (GSM7352Sv2) #show igmpsnooping Admin Mode..................................... Enable Multicast Control Frame Count.................. 0 IGMP header validation......................... Enabled Interfaces Enabled for IGMP Snooping........... None VLANs enabled for IGMP snooping................ 10 15- DaneAAug 01, 2017NETGEAR Employee Retired
Hi robfantini,
As far as I know, the best practice is to use the IP address of the appropriate switch virtual interface as the IGMP Querier Address. If ever the switch does not have a switch virtual interface, you can use an unused IP address within the same subnet as the target VLAN.
Let me share this forum thread and it might help as reference.
DaneA
NETGEAR Community Team
- DaneAAug 03, 2017NETGEAR Employee Retired
The switch virtual interface is the IP Address you have assigned on a specific VLAN. This is best described if you have configured VLAN Routing on the switch. In order to route between VLANs, VLAN interfaces must have IP addresses. For example: VLAN 10 has a network IP Address of 192.168.10.0. You can assign an IP Address to VLAN 10 such as 192.168.10.1 or 192.168.10.254.
DaneA
- robfantiniAug 01, 2017Aspirant
could you please point to information on how to determine a 'appropriate switch virtual interface ' ?
thank you for the help so far.
