robfantini
Jul 30, 2017Aspirant
igmp querier address
we run two linux clusters. they use different vlans. they are attached to the stack using LAGS . Now we need to set up IGMP querier and IGMP snooping . Per this document https://kb.netgear...
- Aug 05, 2017
Hi,
These querier addresses can be anything you want really. It is not any actual ip address. What is it then? It is used as part of an election process. There can only be one querier active in a network. If multiple queriers are configured then an election process will begin. Who will be elected the active querier? The switch that has the lowest ip address value configured, in the querier ip field.
So, it is not a good idea to set the querier ip to the same as the switch. It should instead be setup up as an election model. What I would do, is set querier address 1.1.1.1 on the switch I want to be igmp querier primarily. The others I would set 2.2.2.2, 3.3.3.3, etc. As a hierarchical system: if the current querier goes down then the switch with the next lowest querier ip value would take over as querier.
This is important because you probably want your core/distribution switch to be the main querier.
Cheers
Hopchen
Aug 05, 2017Prodigy
Looks fine yeah.
Notice for your VLAN 10, the Querier VLAN Address is 0.0.0.0. The reason for this is because you can configure a querier two ways:
1. Set a "global" querier address for all VLANs on that switch, which is what you did.
2. Set a unique querier address for each individual VLAN. That can be useful in certain scenarios where you might want switch A to be the querier for VLAN x and switch B to be querier for vlan y.
Most people would probably be fine with the first option, as you have done as well.
Don't forget that you still need to configure IGMP snooping as well, on the switch(es).
Cheers
robfantini
Aug 05, 2017Aspirant
re: Don't forget that you still need to configure IGMP snooping as well, on the switch(es).
I'll research in depth later . in mean time using web/gui I did this:
1- at IGMP Global Configuration - I enabled.
2- at GMP Routing Interface Configuration - I enabled adminn mode for the 2 vlans.
