dialsc
Nov 24, 2016Guide
IGMP/MLD version incompatibility between M5300 switches
Hi all, I'm facing a strange problem and start to think that this is a firmware issue. But as I'm not 100% sure if I got all the concepts/RFCs right, I might also be wrong so I decided to start t...
DanielZhang
Nov 26, 2016NETGEAR Expert
Hi dialsc,
Thanks for your information.
We had receive the diagnostic file you send to us.
The configuration and application information are very useful to us.
We will analyze and reproduce the same scenario just like yours.
So Please use the work around solution just now before we trigger out your concern.
BTW, I also have two question for you.
1) Did you want to limit IGMP/MLD report&query traffic on access switch or stack?
It means that the Multicast Router will collect all report packets in special VLAN then forward out on enabled port.
Any other port will not receive report packets send by other client.
2) Did you want to deploy the IGMP/MLD L3 and L2 querier both on Stackand access switch?
That will confuse the client that two query packets send with different IGMP/MLD version at the same time.
Also the version of L2 querier only support V1/V2 but the L3 querier support V1/V2/V3.
normally there should be only one querier in same VLAN and same device.
but different device maybe have two or more querier in same VLAN.
Daniel.
- dialscNov 26, 2016Guide
Hi Daniel,
Thanks for taking care about this one. Here are the answers to your questions:
1) I hope I got the question right. Is your question related to having IGMP/MLD Snooping enabled on both, the access as well as the stack switch? If so, here's the answer. If not, please let me know... ;)
I've got IGMP/MLD Snooping enabled on both switches because of what I think I figured out. This is, if you do not have either of these two enabled, the M5300 is not forwarding multicast at all. At least I've seen a lot more problems regarding multicast not working as long as IGMP/MLD Snooping is not enabled on either one of the two switches. This is espacially true for IPv6 -> MLD. If I do not enable MLD Snooping, IPv6 traffic is not working propperly/reliable on the M5300 switches in general.
Furthermore, regarding the access switch I thought it might be exactly the right thing to enable IGMP/MLD Snooping on that switch because here I want the individual multicast traffic to only reach the end devices interessted in the individual multicast traffic.
2) No, I only want the stack switch do act as the IGMP/MLD querier. I guess you've seen that I also have VLANs configured for the IGMP and MLD Querier on the access switch. If you take another look you will also see that the querier role is not enabled on the access switch, neither for IGMP nor for MLD. I applied this configuration because of the following:
- As I thought, the access switch is not acting as a querier for IGMP/MLD as long as these roles are disbabled in the configuration.
- Having the VLANs configured in the IGMP/MLD Querier sections allows me to see which switch is currently being reckognized by the access switch as the querier. This is the main purpose of having the VLANs configured there.
Furthermore I think it behaves exactly like I thought it would. On the network itself - using Wireshark - I only see IGMP/MLD queries sent out by the stack switch.
Maybe the following explanation might be also useful to you. The scenario I'm talking about here is more ore less just an extract of our network. The stack switch described here is acctually acting as a distribution switch which and also as an area border router in our OSPF setup. Therefore I configured it to also be the MCast Router in the OSPF area it acts as the ABR for. This stack servs more than just one VLAN, as you've propperly seen already. I just wanted to make it as simple as possible when I started to describe the problem here and therefore I was just taking about one VLAN running over these two switches, especially the stack switch.
Given the fact that the stack switch acts as an ABR as well as the MCast Router for several VLANs in its area I thought it would make a lot of sence to also let this switch act as the IGMP and MLD querier so everything regarding OSPF, IGMP and MLD MCast Routing/Queriing runs at this switch.
I really hope this helps and if not, please let me know. I would be happy to help you as much as possible.
Best regards.
dialsc
- Carl_zNov 30, 2016NETGEAR Expert
Hi dialsc,
Here,I want to mention that for IGMPv3 and MLDv2 we need to check multicast tables via CLI.
I tried with your configuration on local, but can reproduce your issue.
The test result:
ipv4 sender
ipv4 receiver
ipv6 sender
ipv6 receiver
multicast tables on switch
Also I will send your my configuration files via private message. Hope it helps for you.
Regards
Carl
Netgear Employee
- dialscDec 01, 2016Guide
Hi Carl,
thank you very much for taking a look to this and your answer. I think the reason why it is working for you is because you applied the workaround I mentioned in my original post in your configuration as well. Here's the extract of the configuration you sent to me:
interface vlan 48
routing
ip address 192.168.48.1 255.255.240.0
ip ospf area 0.0.0.3
ip ospf cost 10
ipv6 address 2a02:120d:5033:c211::1/64
ipv6 enable
ipv6 nd managed-config-flag
ipv6 nd other-config-flag
ipv6 nd ra-interval 30 22
ipv6 mld router
ipv6 mld query-interval 30
ipv6 mld version 1
ipv6 pim
ipv6 ospf area 0.0.0.3
ipv6 ospf cost 10
ip igmp
ip igmp version 1
ip pim
exitIf I'm not totally wrong you are running the IMGP querier in IGMP version 1 and the MLD Querier in MLD version 1. This is what I wront would work. BUT what does not work, at least for me, is to apply the following, the default versions on the MCR, the stacked switch which acts as the IGMP/MLD Querier (in your setting SW1):
interface vlan 48
routing
ipv6 mld version 2
ip igmp version 3Do you mind let it run with this settings and see what happens? I bet multicast is not working as it isn't for me.
Best regards.
dialsc
